/PROP/TYPE5 (RIVET) (Obsolete)
Block Format Keyword Describes the rivet property set.
/PROP/TYPE5/prop_ID/unit_ID or /PROP/RIVET/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Fnmax | Ftmax | Lmax | flag | Iform |
Definition
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
Fnmax | Maximum normal
force (Real) |
Ftmax | Maximum tangential
force (Real) |
Lmax | Maximum length If L > Lmax rivet is broken (Real) |
flag | Rotations transmission flag
(Integer) |
Iform | Formulation flag
(Integer) |
