prop_ID |
Property
identifier. (Integer, maximum 10 digits)
unit_ID |
(Optional) Unit Identifier. (Integer,
maximum 10 digits)
prop_title |
Property
title. (Character, maximum 100 characters)
Mass |
Mass. (Real)
I |
Inertia. (Real)
Skew_ID |
Skew system identifier.
1 (Integer)
sens_ID |
Sensor
identifier. (Integer)
Isflag |
Sensor flag. 6
- =0
- Spring element activated when sens_ID activates and cannot be deactivated.
- =1
- Spring element deactivated when sens_ID activates and cannot be activated.
- =2
- Spring elements are activated, or deactivated state
matches the sensor state and can switch back and forth.
The spring initial length (
) is based the spring
length at the activation time.
(Integer)
Ifail |
Failure criteria.
- = 0
- Uni-directional criteria.
- = 1
- Multi-directional criteria.
(Integer)
Ifail2 |
Failure model flag.
- = 0 (Default)
- Displacement (or rotation) criteria.
- = 1
- Force (or moment) criteria.
- = 3
- Internal energy criteria.
(Integer)
Iequil |
Equilibrium flag. 4
- = 0
- No equilibrium.
- = 1
- Force and moment equilibrium.
(Integer)
Ki |
If
fct_ID1i =
0: Linear loading and unloading stiffness. If
fct_ID1i ≠
0: Only used as unloading stiffness for
elasto-plastic springs.
= 1, 2, 3 are translation
DOF.
= 4, 5, 6 are rotation
DOF.
(Real)
if
= 1, 2, 3
if
= 4, 5, 6
Ci |
Damping. 1
DOF.
DOF.
(Real)
if
= 1, 2, 3
if
= 4, 5, 6
Ai |
Nonlinear stiffness
function scale factor.
DOF.
DOF.
Default = 1.0 (Real)
if
= 1, 2, 3
if
= 4, 5, 6
Bi |
Scale factor for
logarithmic rate effects.
DOF.
DOF.
Default = 0.0 (Real)
if
= 1, 2, 3
if
= 4, 5, 6
Di |
Scale factor for
DOF.
DOF.
if
= 1, 2, 3
if
= 4, 5, 6
fct_ID1i |
Function identifier
defining nonlinear stiffness
. 5
- = 0
- Linear spring with stiffness K.
If
Hi=4:
Function defines upper yield curve.
DOF.
DOF.
(Integer)
Hi |
Spring Hardening flag for
nonlinear spring.
- = 0
- Elastic spring.
- = 1
- Nonlinear elasto-plastic spring with isotropic
hardening.
- = 2
- Nonlinear elasto-plastic spring with uncoupled
hardening.
- = 4
- Nonlinear elastic plastic spring with kinematic
hardening.
- = 5
- Nonlinear elasto-plastic spring with nonlinear
unloading.
- = 6
- Nonlinear elasto-plastic spring with isotropic hardening
and nonlinear unloading.
- = 7
- Nonlinear elastic plastic spring with elastic
hysteresis.
DOF.
DOF.
(Integer)
fct_ID2i |
Function identifier
defining force or moment as a function of spring velocity,
DOF.
DOF.
(Integer)
fct_ID3i |
Function identifier. If
Hi
=4: Defines lower yield curve.
If
Hi
=5: Defines residual displacement or
rotation versus maximum displacement or rotation.
If
Hi
=6: Defines nonlinear unloading
curve.
If
Hi
=7: Defines nonlinear unloading curve.
DOF.
DOF.
(Integer)
fct_ID4i |
Function identifier for
nonlinear damping,
DOF.
DOF.
(Integer)
Negative translation
failure limit.
DOF.
Default = -1030 (Real)
If
Ifail2 =
0 or 1: Failure
displacement. |
If
Ifail2 =
2: Failure force. |
If
Ifail2 =
3: Failure internal energy. |
Negative rotational
failure limit.
DOF.
If
Ifail2 =
0, 1: Failure
rotation. |
If
Ifail2 =
2: Failure moment. |
If
Ifail2 =
Positive translation
failure limit.
DOF.
If
Ifail2 =
0 or 1: Failure
displacement. |
If
Ifail2 =
2: Failure force. |
If
Ifail2 =
Positive rotational
failure limit.
DOF.
If
Ifail2 =
0 or 1: Failure
rotation. |
If
Ifail2 =
If
Ifail2 =
Fi |
Abscissa scale factor for
the damping functions for the
and
DOF.
DOF.
if
= 1, 2, 3
if
= 4, 5, 6
Ei |
Ordinate scale factor for
DOF.
DOF.
(Real)
if
= 1, 2, 3
if
= 4, 5, 6
Ascalei |
the stiffness function
DOF.
DOF.
if
= 1, 2, 3
if
= 4, 5, 6
Hscalei |
DOF.
DOF.
if
= 1, 2, 3
if
= 4, 5, 6
