An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
Interface TYPE16 allows defining contact conditions between a group of nodes (secondary) and a
curve surface of quadratic elements (main part), as shown in Figure 1 for a symmetric contact. The main part may be made of 16-node thick shells or
20-node bricks. The Lagrange Multiplier method is used to apply the contact conditions;
therefore, no gap is necessary to be applied. Some applications of this interface are sliding
contacts without gaps as in gear box modeling. Figure 1. Interface TYPE16 - Node to Quadratic Surface Contact
Interface TYPE17 allows modeling contact between two quadratic surfaces using the Lagrange
Multiplier method. It is a generalized form of interface TYPE16 in which the contact on the
two quadratic surfaces are directly resolved. The contact is supposed to be sliding or
tied. Figure 2. Interface TYPE17 - Quadratic Surface to Quadratic Surface Contact
As defined above, both interfaces do not model friction effects. Contact is either considered as
tied or without friction (pure sliding).
Note: When using interfaces with the
Lagrange Multiplier method, it is not recommended to symmetrize the contact.
Tied Interface (/INTER/TYPE10)
This interface is similar to interface TYPE7, except for the stiffness which remains
constant during the contact.
Moreover, after impact a secondary node becomes tied to the main surface with or without rebound
(flag Itied).
Stiffness
During impact, a mass-less spring with constant stiffness is added in order to push the secondary
node back. Moreover, as the secondary node is tied, a second massless spring is used
to maintain the secondary node close to its impact point. Depending on whether or
not rebound is allowed, these two springs are maintained when the secondary node is
no longer penetrated. Figure 3. Interface TYPE10
