/RWALL
Block Format Keyword Defines the following types of rigid walls: Infinite Plane, Infinite Cylinder, Sphere and Parallelogram.
/RWALL/type/rwall_ID/unit_ID
rwall_title
node_ID Slide grnd_ID1 grnd_ID2
Dsearch fric ϕ ffac ifq
If node_ID = 0
XM YM ZM
If node_ID0
Mass VX0 VY0 VZ0
If type is Plane, Cyl, Paral.
XM1 YM1 ZM1
If type is Paral.
XM2 YM2 ZM2
Definition
type Rigid wall type keyword.
(see table below)
rwall_ID Rigid wall identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
rwall_title Rigid wall title.
node_ID Node identifier (moving rigid wall).
(Integer)
Slide Sliding flag.
= 0
Sliding
= 1
Tied
= 2
Sliding with friction
(Integer)
grnd_ID1 Node group defining secondary nodes to be added to the rigid wall.
(Integer)
grnd_ID2 Node group defining secondary nodes to be deleted from the rigid wall.
(Integer)
Dsearch Distance for secondary search.
(Real)
[ m ]
fric Friction.
(Real)
ϕ Diameter of the sphere.
(Real)
[ m ]
ffac Filtering factor.
The default value depends on the ifq flag (Real)
ifq Filtering flag. 5
= 0 (Default)
No filter is used.
= 1
f f a c = α MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaiaadA gacaWGHbGaam4yaiabg2da9iabeg7aHbaa@3C40@ , a simple filtering value between 0 and 1.
= 2
ffac =N, the of time steps to apply the filter.
= 3
ffac=freq, cutoff filtering frequency.
Default = 0 (Integer)
XM X coordinate of M.
(Real)
YM Y coordinate of M.
(Real)
ZM Z coordinate of M.
(Real)
Mass Mass of the rigid wall. 8
If no mass is entered, the rigid wall will have a constant imposed velocity.
(Real)
[ kg ]
VX0 Initial velocity in X direction.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VY0 Initial velocity in Y direction.
(Real)
VZ0 Initial velocity in Z direction.
(Real)
XM1 X coordinate of M1.
(Real)
YM1 Y coordinate of M1.
(Real)
ZM1 Z coordinate of M1.
(Real)
XM2 X coordinate of M2.
(Real)
YM2 Y coordinate of M2.
(Real)
ZM2 Z coordinate of M2.
(Real)
Rigid Wall Type
PLANE
¯ plane
CYL
¯ Cylinder of diameter ϕ
SPHER
Sphere of diameter ϕ
PARAL
Parallelogram
Surface Input Type
PLANE
MM1 defines the normal direction
rwall_lagmul_plane2
CYL
MM1 defines the axis of the cylinder
rwall_cyl
SPHER
M is the center of the sphere
rwall_spher
PARAL
M M 1 and M M 2 define the parallelogram
rwall_paral
  1. The first input defines the rigid wall coordinates of one point M or a node_ID in case of moving rigid wall.
  2. The next input is the coordinate of a point M1 and possibly a point M2 (in case of a moving wall, M1 and M2 have the same motion as node_ID).
  3. The secondary nodes to a rigid wall can be defined as a group of nodes and/or as nodes initially at a distance less than the distance (Dsearch) from the rigid wall.
  4. The friction filtering option is only available for a slide rigid wall with friction (Slide =2).
  5. Filtering flag ifg
    If ifq0, the tangential (friction) forces in each secondary node in contact are filtered using a simple rule:
    (1)
    F T f = α F T ( t ) + ( 1 α ) F T f ( t d t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaGccqGH9aqpcqaHXoqycaWHgbWaaSba aSqaaiaadsfaaeqaaOGaaiikaiaadshacaGGPaGaey4kaSYaaeWaae aacaaIXaGaeyOeI0IaeqySdegacaGLOaGaayzkaaGaaCOramaaBaaa leaacaWGubGaamOzaaqabaGccaGGOaGaamiDaiabgkHiTiaadsgaca WG0bGaaiykaaaa@4D30@
    Where,
    F T f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaaaaa@38B5@
    Filtered tangential force.
    F T ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubaabeaakiaacIcacaWG0bGaaiykaaaa@3A26@
    Calculated tangential force at time t before filtering.
    F T f ( t d t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaGccaGGOaGaamiDaiabgkHiTiaadsga caWG0bGaaiykaaaa@3DE0@
    Filtered tangential force at the previous time step
    t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaads haaaa@37D8@
    Current simulation time
    d t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaads haaaa@37D8@
    Current simulation time step
    α MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3796@
    Filtering coefficient
    The flag ifq defines a method for filtering, α coefficient.
    If ifq =1, filtering coefficient is directly input by you: α = f f a c
    If ifq =2, α corresponds to a 3dB filtering level for user-defined frequency (frequency defined in terms of time step number):(2)
    α = 2 π N
    with 1 f r e q = T = N d t , and N = f f a c MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtaiabg2 da9iaadAgacaWGMbGaamyyaiaadogaaaa@3B73@
    If ifq =3, α corresponds to a 3dB filtering level for user-defined frequency:(3)
    α = 2 π d t f r e q MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=viVeYth9vqqj=hEeuD0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqySdeMaeyypa0JaaGOmaiabec8aWjaadsgacaWG0bGaeyyXICTa amOzaiaadkhacaWGLbGaamyCaaaa@46D6@
    Where,
    Time step
    f r e q MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaiaadk hacaWGLbGaamyCaaaa@39B8@
    ffac
  6. The sphere (SPHER) and parallelogram (PARAL) are not infinite. For parallelograms, the normal is defined using:(4)
    M M 1 × M M 2
    and the diameter of the sphere is defined using ϕ .
  7. Nodal thickness of rigid wall secondary nodes is not taken into account.
  8. For moving rigid walls with MASS=0 or blank, the rigid wall will have a constant imposed velocity and not an initial velocity.
