/SECT/PARAL
Block Format Keyword A parallelogram section is used to output the force and moment of a cross section defined by a parallelogram.
The nodes and elements that define the section are automatically selected by intersecting the groups of elements with a parallelogram.
/SECT/PARAL/sect_ID/unit_ID | |||||||||
sect_title | |||||||||
node_ID1 | node_ID2 | node_ID3 | ISAVE | ||||||
file_name | |||||||||
grbric_ID | grshel_ID | grtrus_ID | grbeam_ID | grsprg_ID | grtria_ID | Ninter | Iframe |
int_ID1 | int_ID2 | int_ID3 | int_ID4 | int_ID5 | int_ID6 | int_ID7 | int_ID8 | int_ID9 | int_ID10 |
XM | YM | ZM | |||||||
XM1 | YM1 | ZM1 | |||||||
XM2 | YM2 | ZM2 |
Definition
sect_ID | Section
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
sect_title | Section
title. (Character, maximum 100 characters) |
node_ID1 | Node identifier N1 defining the local output system of the
section. (Integer) |
node_ID2 | Node identifier N2 defining the local output system of the
node_ID3 | Node identifier N3 defining the local output system of the section.
(Integer) |
ISAVE | Flag for saving or reading
the section data from file_name.
(Integer) |
Time step for saving the
section data used with
ISAVE
=1 or 2. Default = time step of the simulation (Real) |
Exponential moving average
filtering constant (0 <
< 1). Smaller values result in
more filtering. Only used when applying the displacements to a section using ISAVE= 100 or 101. Recommended value =0.62832 (Refer to Filter in the User Guide) Default = No filtering (Real) |
file_name | Root name of the file
which contains the flag output. The section file will be named
file_nameSC01. Default = Runname (where, Runname is the prefix to the Engine file, Runname_0001.rad) (Character, maximum 100 characters) |
grbric_ID | Brick group
identifier. (Integer) |
grshel_ID | Shell group
grtrus_ID | Truss group
grbeam_ID | Beam group
grsprg_ID | Spring group
grtriag_ID | Triangle group
Ninter | Number of
interfaces. (Integer) |
Iframe | Flag defining the center
of the local system used in the calculation of the section forces
and moments. 3
The section output is in the local system with the center defined as:
The section output is in the global system with the
center defined as:
(Integer) |
int_ID1, int_ID2, ..., int_IDn | Optional interface
identifiers, if Ninter >
0. (Integer) |
XM | X
coordinate of M. (Real) |
YM | Y
ZM | Z
XM1 | X
coordinate of M1. (Real) |
YM1 | Y
ZM1 | Z
XM2 | X
coordinate of M2. (Real) |
YM2 | Y
ZM2 | Z
- The elements groups defined will be intersected by the defined parallelogram. The lines M–M1 and M–M2 (Figure 1) define the parallelogram. The section nodes are created from the nodes of those intersected elements, which are on the upside (z > 0) of the plane of the parallelogram.
- The forces and moments from the sections will be stored in the time history file and requested using /TH/SECTIO.
- The local force and moment output
system of the section is defined using 3 nodes. These three nodes should be
nodes on the section plane, so their position is updated when the section moves.
When using the Cross-Section Assistant in HyperMesh
to create the section, the 3 nodes are automatically selected.Local system is defined as:
- Nodes node_ID1 and node_ID2 define the local x-axis of the section.
- Nodes node_ID1, node_ID2, and node_ID3 define the local plane xy of the section.
- The local y-axis is defined by projecting node_ID3 perpendicular to the local x-axis.
- The intersection of the local x- and y-axis is then the origin of the system.
- Last, the section normal is the local z-axis which is perpendicular to the xy plane.
- The center of the section can be redefined using the Iframe option. Refer to Force and Moment Computation in the User Guide for further details.
- Sections can also be used in a cut modeling method where section forces and displacements are saved from a full model and then applied in a second cut model. In the full model, the section information is saved using the ISAVE =1 or 2 option. Then in the cut model, the same section nodes and element groups are defined and the section displacements are applied to the cut model using ISAVE =100 or 101. The cut model is then used to study a detailed area of the full model.
- Recommendations:
- Define Iframe =2 or 12, the center is the CoG of the section.
- Time history output GLOBAL and LOCAL in /TH/SECTIO.
