*SECTION_SOLID
LS-DYNA Input Interface KeywordDefines the finite element properties of solid elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*SECTION_SOLID
sec_ID ELFORM
Definition
sec_ID Section identifier.
(Integer)
ELFORM Solid element formulation options.
= 0
Set to 1.
= 1 (Default)
HEPH 8-node solid element, 1 Gauss integration point, co-rotational system formulation, physical hourglass stabilization.
= 2
8-node solid element, co-rotational, full integration, fixed 2*2*2 Gauss integration points, shear locking-free.
= 10 or 13
4 node tetrahedral element.
= 16
10 node tetrahedral element.
= 19 or 20
8-node solid connection element.
(Integer)
  1. This keyword maps to /PROP/TYPE14 (SOLID) for an isotropic material and /PROP/TYPE6 (SOL_ORTH) for an orthotropic material. For connection elements ELFORM = 19 or 20, this keyword maps to /PROP/TYPE43 (CONNECT).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
