/SENSOR/SECT
Block Format Keyword Describes the sensors used to activate or deactivate an object according to section force.
/SENSOR/SECT/sens_ID/unit_ID
sens_title
Tdelay
sect_ID DIR Fmin Fmax Tmin
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
sect_ID Section identifier.
DIR Force direction.
blank
Activation at first force or moment
TF
Total Force
TM
Total Moment
FN
Normal Force
FT
Tangent Force
FX
Force in X direction
FY
Force in Y direction
FZ
Force in Z direction
MX
Moment in X direction
MY
Moment in Y direction
MZ
Moment in Z direction
(Integer)
Fmin Minimum force.
Default = 0 (Real, maximum 20 fields)
[ N ]
Fmax Maximum force.
[ N ]
Tmin Minimum time duration before activation when criteria is reached. 3
(Real)
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type SECT:
    Sensor is activated when section force satisfies the criteria:
    • F s e c t < F min or F s e c t > F max during Tmin
    Dir defines Force direction:
    TF
    Total Force
    TM
    Total Moment
    FN
    Normal Force
    FT
    Tangent Force
    FX
    FY
    FZ
    MX
    MY
    MZ
  4. Values for force and moment component limits in the force-based sensors (SECT) can be positive and negative. Normal, tangent, total force and moment values are always positive.
