/SKEW/MOV2
Block Format Keyword Describes a moving local coordinate system.
/SKEW/MOV2/skew_ID | |||||||||
skew_title | |||||||||
node_ID1 | node_ID2 | node_ID3 |
Definition
skew_ID | Skew
skew_title | Skew title (Character, maximum 100 characters) |
node_ID1 | Node identifier
N1 (Integer) |
node_ID2 | Node identifier
N2 (Integer) |
node_ID3 | Node identifier
N3 (Integer) |
- Moving skew defines a local coordinate system, defined by three nodes. At each time, the actual orientation of the skew is recalculated according to the actual position of these nodes.
- In 3D, the skew is defined as:
node_ID1 and node_ID2 define
node_ID1 and node_ID3 define
(1) (2) - When defining some conditions with
respect to the skew in cylindrical coordinate system, the axis of the
cylindrical coordinate system is assumed to pass through node
N1.
