/SPHCEL
Block Format Keyword Describes the SPH cells.
/SPHCEL/part_ID
node_ID
Definition
Field Contents SI Unit Examples
part_ID Part identifier.
(Integer, maximum 10 digits)
node_ID Supporting node identifier.
(Integer)
  1. The particles will have the same identifier as their supporting node.
  2. The particles should be distributed with respect to a hexagonal compact net or a cubic net (refer to SPH Cells Distribution).
