/STOP/LSENSOR
Engine Keyword The Engine is stopped due to sensor activation, when the first sensor in the defined list is activated.
/STOP/LSENSOR
sensor_IDUi sensor_ID2 ... sensor_IDn
NTH NANIM Nsta Noutput Nabf Nh3d Ndynain
Definition
sensor_IDi Sensor identifier.
NTH
= 0 (Default)
The Engine is stopped without ending the Time History file.
= 1
A Time History file writing is ended if the Engine is stopped, due to sensor activation.
NANIM
= 0 (Default)
The Engine is stopped without animation file.
= 1
An animation file is written if the Engine is stopped, due to sensor activation.
Nsta
= 0 (Default)
The Engine is stopped without .sta file.
= 1
A state file (.sta) is written if the Engine is stopped, due to sensor activation.
Noutput
= 0 (Default)
= 1
An ASCII output files (STY-File) is written if the Engine is stopped, due to sensor activation.
Nabf
= 0 (Default)
The Engine is stopped without ending the .abf file.
= 1
An .abf file writing is ended if the Engine is stopped, due to sensor activation.
Nh3d
= 0 (Default)
The Engine is stopped without writing current data to the .h3d file.
= 1
Data is written to the .h3d file when the Engine is stopped, due to sensor activation.
Ndynain
=0 (Default)
The Engine is stopped without an .dynain file.
= 1
A state file (.dynain) is written if the Engine is stopped, due to sensor activation.
  1. A restart file is written if the Engine is stopped, due to one of these events.
