/SURF/GRBRIC/EXT
Block Format Keyword Describes the external surface selection from 3D element groups.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/GRBRIC/EXT/surf_ID/unit_ID
surf_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
Definition
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
item_ID1, item_ID2,... item_IDn List of brick group identifiers
(Integer)
  1. A surface cannot be defined using Madymo surfaces.
  2. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
