/TABLE/1
Block Format Keyword Defines a table with up to four dimensions using functions and/or data points.
/TABLE/1/table_ID
table_title
dimension
If dimension=1, similar to /FUNCT
X1 Y1
etc etc
Xn Yn
If dimension=2
fct_ID1   A1         Scale_y1
etc   etc         etc
fct_IDn   An         Scale_yn
If dimension=3
fct_ID1   A1 B1     Scale_y1
etc   etc etc     etc
fct_IDn   An Bn     Scale_yn
If dimension=4
fct_ID1   A1 B1 C1 Scale_y1
etc   etc etc etc etc
fct_IDn   An Bn Cn Scale_yn
Definition
table_ID Table identifier.
(Integer, maximum 10 digits)
table_title Table title.
dimension Total number of entries.
(Integer ≤ 4)
Xi - Xn ith abscissa value, where 1 ≤ i ≤ n.
(Real)
Yi - Yn ith ordinate value, where 1 ≤ i ≤ n.
(Real)
fct_IDi ith function identifier, where 1 ≤ i ≤ n.
(Real)
Ai ith A value, corresponding to fct_IDi, where 1 ≤ i ≤ n.
Default = 0 (Real)
Bi ith B value, corresponding to fct_IDi, where 1 ≤ i ≤ n.
Default = 0 (Real)
Ci ith C value, corresponding to fct_IDi, where 1 ≤ i ≤ n.
Default = 0 (Real)
Scale_yi Scale factor for the ordinate of the ith function, where 1 ≤ i ≤ n.
Default = 1 (Real)
For dimension=1 is actually stress-plastic strain curve.
X
Plastic strain
Y
Stress
For dimension=3, yield stress depending on plastic strain, strain rate and temperature could be considered.
In /FUNCT
X
Plastic strain
Y
Stress
In /TABLE
Ai
Strain rate
Bi
Temperature
/TABLE/1/1007
table type 1 with dimension 1 (same like /FUNCT)
#DIMENSION
         1
#                  X                   T
                   0                   0
                 0.1                 210
                 0.2                 220
                 0.3                 225
                 0.5                 228
/TABLE/1/1008
table type 1 with dimension 3
#DIMENSION
         3
#   FCT_ID                             Y                   Z
      4173                             1                 300                                       1
      4174                             5                 300                                     1.2
/FUNCT/4173
New FUNCT 4713
#                  X                   Y
                   0                   0
                 0.1                 210
                 0.2                 220
                 0.3                 225
                 0.5                 228
/FUNCT/4174
New FUNCT 4714
#                  X                   Y
                   0                   0
                 0.1                 210
                 0.2                 220
                 0.3                 225
                 0.5                 228
#enddata
  1. The input of dimension=1 is similar to the input of a function /FUNCT.
  2. A function and a table cannot share the same identifier.
  3. Each function which is referenced can be defined through /FUNCT or /TABLE/1/table_ID and dimension=1.
  4. The abscissa of associated functions is considered as the first entry. Next, the input entries A, B and C are considered as second, third and fourth entries.
  5. A function must be associated to each possible combination of entries A, B, and C.
  6. The cards associating functions to the combinations of entries may be entered in an arbitrary order.
  7. Each function may have unique spacing and arbitrary number of points in their definition.
  8. The functions are completed up to the total number of abscissa values among all functions which are referenced into the table: each function is linearly extrapolated with a slope defined by the two first (resp. two last) points of the function. It is linearly interpolated between two consecutive points of the function.
