/TETRA4
Block Format Keyword Describes a tetrahedral solid element with 4 nodes.
/TETRA4/part_ID
tetra_ID node_ID1 node_ID2 node_ID3 node_ID4
Definition
Field Contents SI Unit Examples
part_ID Part identifier of the block.
(Integer, maximum 10 digits)
tetra_ID Element identifier.
(Integer)
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
node_ID3 Node identifier 3.
(Integer)
node_ID4 Node identifier 4.
(Integer)
  1. The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
  2. The part_ID of the tetrahedral 4-node elements must be different from:
    • the part_ID of the brick element
    • the part_ID of the tetrahedral 10-node element
      clip0140
    The 4-node tetrahedral elements are treated internally as solid elements (brick_ID), using solid materials and solid groups (grbric_ID).
