/TH/RETRACTOR
Block Format Keyword Describes the time history for retractors.
/TH/RETRACTOR/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
Definition
thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
thgroup_name | TH
group name (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH. See TH Output Keyword &
Variables. (Character, maximum 8 characters) |
Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
RETRACTOR | Retractors | SLIP, FN, LOCK |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
RETRACTOR | DEF | SLIP, FN, LOCK |
Output for Retractors
- SLIP: total amount of material released by the retractor
- FN: force exerted by retractor
- LOCK: status of the retractor (locked =1 / unlocked = 0)
- The slip is positive when the material is pulled out of the retractor and negative when material is pulled in.
