/TH/SURF
Block Format Keyword Describes the time history output variables for surfaces.
/TH/SURF/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
obj_ID1 | obj_ID2 | obj_ID3 | obj_ID4 | obj_ID5 | obj_ID6 | obj_ID7 | obj_ID8 | obj_ID9 | obj_ID10 |
Definition
thgroup_ID | Time history group
thgroup_name | Time history group
name (Character, maximum 100 characters) |
var_ID1, ..n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
obj_ID1, ..n | Identifiers of the
surfaces to be saved (Integers) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
SURF | Surfaces | AREA, MASSFLOW, VELOCITY |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
SURF | DEF | AREA |
Output Variable for Surfaces
- AREA: Area of the surface
- MASSFLOW: Accumulated mass flowing through the surface
- VELOCITY: Flow velocity across the surface
- Variable names must be left justified.
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
- Surfaces must be defined by shell elements.
- MASSFLOW and VELOCITY are only available for internal surfaces of /MONVOL/FVMBAG1 and communication surfaces of /MONVOL/COMMU1.
