/TH/TRUSS
Block Format Keyword Describes the time history for trusses.
/TH/TRUSS/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
elem_ID   elem_name
Definition
thgroup_ID TH group identifier
(Integer, maximum 10 digits)
thgroup_name TH group name
var_ID1, ...n Variables saved for TH (see table below)
(Character, maximum 8 characters)
elem_ID Element identifier
(Integer)
elem_name Name of the element to appear in the time history
(Integer, maximum 80 characters)
TH Output Keyword & Variables
Keyword Object Saved Variables
TRUSS Trusses OFF, F, IE, A, L, PLAS
Table of Available Variables - Part 2
Keyword Variable group Saved TH Variables
TRUSS DEF OFF, F, IE, PLAS
Output for Available Material Law
Output Material Law
OFF: element flag for deactivation 2 /PLAS_PREDEF, 1, 2, 44
F: normal force /PLAS_PREDEF, 1, 2, 44
IE: internal energy /PLAS_PREDEF, 1, 2, 44
A: area /PLAS_PREDEF, 1, 2, 44
L: initial length /PLAS_PREDEF, 1, 2, 44
PLAS: equivalent plastic strain /PLAS_PREDEF, 2, 44
  1. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
  2. OFF:
    • 0.0 deleted element
    • 1.0 active element
    • 2.0 (shells / solids): active element using small strain
    • Negative value -1/-2 when the element is on stand by due to rigid body
    Some intermediate values can be found during few cycles before element deletion (progressive reduction of off during a few cycles applies as a multiplicative factor to the stress, so that the stress is progressively vanished and element is deleted after ~ 10 cycles). This process applies to some element types, but not all.
