/THERMAL
Engine Keyword Thermal analysis.
/THERMAL
time-factor
Definition
time-factor | Factor to speed-up the
thermal analysis Default = 1 |
- The physical time will be reduced by time-factor. All thermal properties will be automatically scaled, no need to change the Radioss Starter inputs. Time values in Radioss Engine input file must be modified.
- Works for thermal analysis with solid, shell and sph elements.
