/THPART/GRSPRI
Block Format Keyword Defines a Thpart.
/THPART/GRSPRI/Thpart_ID | |||||||||
Thpart_title | |||||||||
grelem_ID |
Definition
type | Type of input (see Time Histories (Part definitions) for available keywords) |
Thpart_ID | Part identifier of the
block (Integer, maximum 10 digits) |
Thpart_title | TH part
grelem_ID | Element group
- A Thpart_ID must be different from all Part_IDs of the deck.
- A Thpart can be used, as well as PART in option /TH/PART.
