/TRANSFORM/ROT
Block Format Keyword Defines a rotation for a node group around a defined axis, center of rotation and rotation angle.
/TRANSFORM/ROT/transform_ID/unit_ID
transform_title
grnd_ID X_point_1 Y_point_1 Z_point_1 node_ID1 node_ID2 sub_ID
  X_point_2 Y_point_2 Z_point_2 Angle
Definition
transform_ID Transformation identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
transform_title Transformation title
grnd_ID Node group identifier. 5
(Integer)
X_point_1 X coordinate of point 1.
Default = 0.0 (Real)
Y_point_1 Y coordinate of point 1.
Z_point_1 Z coordinate of point 1.
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
sub_ID Submodel identifier.
(Integer)
X_point_2 X coordinate of point 2.
Y_point_2 Y coordinate of point 2.
Z_point_2 Z coordinate of point 2.
Angle Rotation angle value (in degree's).
[ deg ]
  1. If node_ID1 and node_ID2 are defined, the rotation will be done around the vector defined by node_ID1 and node_ID2. The center of rotation will be the node_ID1. If only one node is defined, the error message is displayed.
    transform_rot_node
    Otherwise, the rotation will be done around the vector defined by point_1 and point_2. The center of rotation will be the point_1.
    transform_rot_point
  2. A transformation can not apply to a node group and a submodel at the same time.
  3. If the transformation is done on a submodel, all the options of this submodel are transformed.
  4. A node cannot be transformed both in a submodel and a node group.
  5. Transforms applied to node groups via grnd_ID only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed. To provide a complete transformation, the /TRANSFORM card should reference a //SUBMODEL and not a node group.
