The Temperature Update model
This model is originally designed and validated with the Hertz-Mindlin Base model only.
After all the heat fluxes have been calculated, the temperature change over time of each particle is updated explicitly using:
where mp, CP and T are the mass, specific heat capacity and temperature of the particle material type. The RHS denotes the sum of convective and conductive heat fluxes.
| Interaction | Configurable Parameters | Position |
| Particle to Particle (heat conduction) | Set the thermal conductivity for each type of particle. |
Last |
| Particle to Geometry(heat conduction) | Set the thermal conductivity for each type of particle for the particle-geometry contact | Last |
| Particle Body Force (temperature update) | Set the specific heat capacity of the particle | N/A |
| Name | Description and Parameter Values |
| Temperature Update | Although not strictly a force, this built-in model allows the modeling of model external heat sources acting on the particles. It must be used with the Hertz-Mindlin with Heat Conduction contact model as it also completes the calculation of heat transfer between particles in contact. Set the specific heat capacity for each type of particle. |
Using the Temperature Update model
- Select Particle-to-Particle from the Interaction menu in the Physics section of the Creator.
- Click the + dropdown and then select Hertz-Mindlin with Heat Conduction.
- Click the configuration icon to define the thermal conductivity for each particle type.
- Select Particle Body Force from the Interaction menu.
- Click the + dropdown and then select Temperature Update.
- Click the configuration icon to define the specific heat capacity for each particle type.
