Load Configuration for Networks
When a network port is connected to a wire (segment/vertex) or edge port, a load can be defined in series or across the terminals of a network.
Note: A network port refers to a port connected to a general network or transmission
line.
Load Placed in Series with Network
To place a load in series with the network, define the load on the wire
(segment/vertex) or edge port.
Figure 1. The load is placed in series with the network.
Load Placed Across Network
To place the load across the network, define the load on the network port.
Figure 2. The load is placed across the network.
