| 1. | From the Menu Bar, select Model, then Property. |
| 2. | Below are the available options to sort the property list: |
| • | Click |
| • | Click |
| • | Click |
| • | Click |
| 3. | Under Choose Property Law, select a property. |
| 4. | Click |
| 5. | Click |
| 6. | Enter the different values in the fields for the property. |
| • | Set the value or the property name. |
| • | Click the toggle button to switch options ON or OFF. |
| • | Click the button for the function to set or modify a function. |
| • | Set the number of the function needed and click Ok. |
| 7. | Click |
| • | In the new sub-window, select the directory to save the property to (left area part). |
| • | Enter the name of the property to save. |
| • | Select OK to save the property or Cancel to cancel the save. |
| 8. | Click Save to save the property creation; or |
Click Cancel to cancel the property creation.
| 9. | Click Close to close the menu. |
