| 1. | From the Menu Bar, select LoadCase > Imposed Displacement > Create. |
| 2. | Enter a name in the Imposed Displacement Creation field and validate with Ok. |
| 3. | In the function window, enter the function values to import from an already existing function. (Learn how to create the function.) |
| 4. | In the Selections folder, select nodes using the different tools from the Selection folder. |
Button |
Behavior |
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add/remove object by ellipse selection. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add all nodes. |
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
| 5. | In the Reference Axis folder: |
| • | Click the Reference Axis folder. |
| • | Define the reference axis using the different tools of the Reference Axis folder. |
| 6. | In the Sensor folder, define the sensor to activate and deactivate the imposed displacement. (Learn how to create a sensor.) |
| • | In the Scale factor field, set a scale factor for the abscissa of the defined curve. |
| • | Set a starting time in the Start time field. |
| • | Set a stopping time in the Stop time field. |
| 8. | Click Function to modify the function. |
| • | Select Tx, Ty, or Tz to set the imposed displacement in X, Y, or Z direction. |
| 10. | Click Save to save the created imposed displacement; or |
Click Cancel to cancel the imposed displacement creation.
| 11. | Click Close to close the menu. |
