Renumber the entire the model
| 1. | From the Menu Bar, select Mesh Editing > Renumber. |
or
If the Mesh Editing panel is already open, select Renumber from the pull-down menu in the panel.
| 2. | Choose one of the available options: |
| • | Click Default Values to renumber from a predefined value. |
| • | Click User Defined Values to renumber from values defined by you. |
| • | Click Select/Unselect All Entities to select or unselect all entities. |
| • | Click Reverse Selection of Entities to reverse the entities selected. |
| • | From the objects in the detail list window, click the toggle button and set the starting value in the field, ID From: field. The To: field(s) is (are) automatically updated. |
| 3. | Click Renumber to save the changes. |
| 4. | Click Reset to cancel the changes and reset the default values. |
| 5. | Click Close to close the menu. |
See also
Specific Renumber
