/DT/SPHCEL
Engine Keyword Generates the SPH cells time step.
/DT/SPHCEL
| Data | Description | SI Unit Example |
| Scale factor on time step for option SPHCEL. | ||
| Minimum time step for option SPHCEL. |
- /DT/NODA is compatible with SPH.
- Nodal time step is generally more robust.
