Comparison of functions available in SimSolid Basic,
SimSolid Standard, and SimSolid
Advanced.
Capacity
Basic |
Standard |
Advanced |
Limits on assembly face facets |
No limits |
No limits |
No limits |
Limits on parts in the CAD assembly |
No limits |
No limits |
No limits |
Simulation Types
Basic |
Standard |
Advanced |
Linear statics |
Yes |
Yes |
Yes |
Modal |
Yes |
Yes |
Yes |
Thermal steady state |
No |
Yes |
Yes |
Thermal transient |
No |
No |
Yes |
Coupled thermal-stress |
No |
Yes |
Yes |
Geometric non-linear statics |
No |
Yes |
Yes |
Material non-linear statics |
No |
Yes |
Yes |
Coupled material-geometric nonlinear statics |
No |
Yes |
Yes |
Incremental loading non-linear statics |
No |
No |
Yes |
Linear dynamics (time, frequency, random response) |
No |
Yes |
Yes |
Linear buckling |
No |
No |
Yes |
Sequential |
No |
No |
Yes |
Modal Prestressed |
No |
No |
Yes |
Fatigue |
No |
No |
Yes |
Frequency multi-loadcases |
No |
No |
Yes |
Geometry Sources
Basic |
Standard |
Advanced |
Autodesk Fusion 360 direct integration |
Yes |
Yes |
Yes |
Onshape direct integration |
Yes |
Yes |
Yes |
STL files |
Yes |
Yes |
Yes |
ACIS files |
Yes |
Yes |
Yes |
CATIA (V4, V5, V6) files |
Yes |
Yes |
Yes |
CGR files |
Yes |
Yes |
Yes |
Inventor files |
Yes |
Yes |
Yes |
JT files |
Yes |
Yes |
Yes |
NX files |
Yes |
Yes |
Yes |
Parasolid files |
Yes |
Yes |
Yes |
PLMXML files |
Yes |
Yes |
Yes |
PTC/Creo files |
Yes |
Yes |
Yes |
SolidWorks files |
Yes |
Yes |
Yes |
VDA files |
Yes |
Yes |
Yes |
STEP files |
Yes |
Yes |
Yes |
Material Properties
Basic |
Standard |
Advanced |
Isotropic |
Yes |
Yes |
Yes |
Orthotropic |
Yes |
Yes |
Yes |
Rigid |
Yes |
Yes |
Yes |
Non-linear table driven stress-strain curves |
No |
Yes |
Yes |
Assembly Connections
Basic |
Standard |
Advanced |
Bonded |
Yes |
Yes |
Yes |
Sliding |
Yes |
Yes |
Yes |
Separating contact with friction |
No |
Yes |
Yes |
Bolted |
Yes |
Yes |
Yes |
Virtual connectors |
Yes |
Yes |
Yes |
Spot welds |
Yes |
Yes |
Yes |
Laser welds |
Yes |
Yes |
Yes |
Fillet/seam welds |
Yes |
Yes |
Yes |
Adhesives |
Yes |
Yes |
Yes |
Boundary Conditions
Basic |
Standard |
Advanced |
Immovable contstraint |
Yes |
Yes |
Yes |
Sliding constraint |
Yes |
Yes |
Yes |
Hinge constraint |
Yes |
Yes |
Yes |
Spring support (elastic foundation) |
Yes |
Yes |
Yes |
Prescribed displacements |
Yes |
Yes |
Yes |
Pressure |
Yes |
Yes |
Yes |
Force |
Yes |
Yes |
Yes |
Gravity |
Yes |
Yes |
Yes |
Temperature |
Yes |
Yes |
Yes |
Heat flux |
Yes |
Yes |
Yes |
Convection |
Yes |
Yes |
Yes |
Volumetric heat |
Yes |
Yes |
Yes |
Remote Force/moment |
Yes |
Yes |
Yes |
Bearing load |
Yes |
Yes |
Yes |
Bolt/nut preload |
Yes |
Yes |
Yes |
Hydrostatic load |
Yes |
Yes |
Yes |
Translational Inertia load |
Yes |
Yes |
Yes |
Rotational Inertia load |
Yes |
Yes |
Yes |
Distributed mass |
Yes |
Yes |
Yes |
Inertia relief |
Yes |
Yes |
Yes |
Table driven dynamic loads |
No |
Yes |
Yes |
Dynamic base excitation |
No |
Yes |
Yes |
Results Output
Basic |
Standard |
Advanced |
Contour plots |
Yes |
Yes |
Yes |
Animation (static and modal) |
Yes |
Yes |
Yes |
Max/min locations |
Yes |
Yes |
Yes |
Point value probes |
Yes |
Yes |
Yes |
XY plots |
No |
Yes |
Yes |
Reaction/contact forces |
Yes |
Yes |
Yes |
Safety factors |
Yes |
Yes |
Yes |
Frequencies and mode shapes |
Yes |
Yes |
Yes |
Bolt/nut resultant forces |
Yes |
Yes |
Yes |
Spot weld resultant forces |
Yes |
Yes |
Yes |
User Productivity
Basic |
Standard |
Advanced |
Bookmark browser |
Yes |
Yes |
Yes |
Save animation (as .mp4 files) |
Yes |
Yes |
Yes |
Save images (as .png files) |
Yes |
Yes |
Yes |
Units manager |
Yes |
Yes |
Yes |
Default materials |
Yes |
Yes |
Yes |
Custom graphics labels |
Yes |
Yes |
Yes |
Standard views |
Yes |
Yes |
Yes |
User defined views |
Yes |
Yes |
Yes |
Measurement tool |
Yes |
Yes |
Yes |
Spot regions for custom load application |
Yes |
Yes |
Yes |
Command Line Execution
Basic |
Standard |
Advanced |
Installation |
Yes |
Yes |
Yes |
Invocation |
Yes |
Yes |
Yes |
Batch mode |
No |
No |
Yes |
