EDEM can import field data from a simple custom text file. These files are in the following format:
| Line | Description |
| 1 | Filename or description (such as the field name). |
| 2 | Data dimension: 3 for 3D or 2 for a 2D plane. For a 2D plane, the data exists in one plane and is extruded along one dimension to fill the 3D domain in EDEM. For example, X and Y values vary but the Z value is the same for all points. |
| 3 | Element type: 0 for scalar data, 1 for vector data. |
| 4 | Number of points. 0 indicates an unknown number. |
| 5 - n |
The dataset itself, where each line contains a set of coordinates and data values, separated by spaces.
Example Custom Field File:
cartesian_data_tank
3
1
0
-0.240000 -0.237500 -0.750000 0.040000 0.000000 0.000700
-0.250000 -0.237500 -0.750000 0.050000 0.000000 0.000700
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
