This body force model must be used in combination with the Heat Conduction model to ensure the function of the heat conduction algorithm as described in (Chaudhuri, Muzzio and Tomassone 2006). This model is originally designed and validated with the Hertz-Mindlin Base model only.
After all the heat fluxes have been calculated, the temperature change over time of each particle is updated explicitly using:
where mp, CP and T are the mass, specific heat capacity and temperature of the particle material type. The RHS denotes the sum of convective and conductive heat fluxes.
Make sure the Update Temperature particle body force model is added to the particle body force model.
| Interaction | Configurable Parameters | Position |
Particle to Particle (heat conduction) |
Set the thermal conductivity for each type of particle.
Note the unit depends on the temperature unit; for example, the unit will be W/mK when the temperature unit is Kelvin. |
Last |
Particle to Geometry (heat conduction) |
Set the thermal conductivity for each type of particle for the particle-geometry contact.
Set the thermal conductivity for the geometry type in the contact.
Set the temperature of the geometry type. |
Last |
Particle Body Force (temperature update) |
Set the specific heat capacity of the particle |
N/A |
| Name | Description and Parameter Values |
| Temperature Update |
Although not strictly a force, this built-in model allows the modeling of model external heat sources acting on the particles. It must be used with the Hertz-Mindlin with Heat Conduction contact model as it also completes the calculation of heat transfer between particles in contact.
Set the specific heat capacity for each type of particle. Note that the unit depends on the temperature unit; for example, the unit will be Jkg-1K-1 when the temperature unit is Kelvin. |
Use:
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
