Defining variable scope
The variable scope determines how variables are referenced. There are five scope attributes.
Scope
Function
Constant
Constant value used inside the state chart. You can only assign it a default value.
External
For code generation. It is external to the block diagram and defined in handwritten C code outside the diagram.
Input
Passes information to the state chart. You can assign it a type, number, and default value.
Local
Value used inside the state chart.
Output
Passes information from the state chart to the block diagram. You can assign it a type, number, and default value.
