Block Category: Draw
Input Image Requirements: Gray scale
Description: The Draw Contour block draws a contour around an image based on three inputs to the block:
• Image: Indicates the gray scale image to which the contour is applied
• Contour: Indicates the contour of the image.
• Hierarchy: If connected, indicates whether the parent-child contour hierarchy is observed.
You typically use this block in conjunction with the Find Contour block.
Thickness: Specifies the contour’s thickness as an integer greater than 0.
