Dynamically modifying signal values
You can dynamically modify a signal value during a simulation using the slider block. This block lets you set upper and lower bounds in one and 10 percent increments.
1.    Insert and wire a slider block into your diagram.
2.    Using the scroll bar, adjust the value to be applied to the signal.
3.    As the simulation proceeds, re-adjust the value of the slider block as necessary.
