Final configuration requirements
Connect the X and Y outputs of Target to the first two input tabs of the Coarse Tracker plot block and the outputs of X Axis Servo and Y Axis Servo actual line of sights to the next two input tabs of the same plot block.
Connect the outputs of the two unitConversion blocks to the first two input connectors of the Focal Plane plot.
You are now ready to run the simulation with the System > Go command.
tuto_36
