General information request - vissimRequest()
The vissimRequest() function provides a general, extensible request mechanism for obtaining information from Embed.
EXPORT32 long vissimRequest(long req, arg2, arg3);
The first argument (long req) is a message code describing the action for Embed to take. The message codes that pertain to writing a custom block are as follows:
Message
VR_CG_GET_TIMER_FUNC
Returns name of main interrupt function.
VR_CG_REWRITE_LOCAL_VAR_STR
Reserved.
VR_CHECK_PORT_NAME_SYNTAX
Reserved.
VR_CLEAR_BLOCK
Clears red error state on block. Uses currently executing block if block handle in arg1 is null.
arg1:   Block handle (opt.)
VR_CLEAR_BLOCK_ERR
VR_CODE_GEN
Activates code generation on the current diagram.
arg2:   Pointer to C file name
VR_DISABLE_BLOCK_TYPE
Removes block matching name string from Blocks menu.
arg1:   LPSTR name string
VR_ENABLE_MENU_ITEM
Enables menu item.
arg1:   char* name of menu item to be enabled
VR_EXECUTE
Runs diagram but doesn’t change time (no integration).
VR_EXECUTE_CONST_BLOCK
Reserved.
VR_EXPAND_PATH_ALIAS
Returns pointer (LPCSTR) to expanded path alias.
arg1:   Pointer (LPCSTR) to input alias
VR_GET_BLOCK_FLAGS
Returns existing block flags. VBF_* are the flogs. OR them together to get the flags you want.
arg1:   Block handle
VR_GET_BLOCK_ID
Returns an integer that uniquely identifies the block.
VR_GET_BLOCK_INPUT
Returns the pointer to the input SIGNAL vector.
arg1:   Block handle
VR_GET_BLOCK_OUTPUT
Returns the pointer to the output SIGNAL vector.
arg1:   Block handle
VR_GET_BLOCK_PARAMS
Returns block parameter pointer.
arg1:   Block handle
VR_GET_BLOCK_POS
Returns block position.
VR_GET_CODEGEN_FLAGS
Returns a bit vector of three possible flags that are OR’ed together. Flags can be check by AND’ing the named flag with the returned word. Flag names:
VRCG_FLG_HAS_COMM_INTERFACE: User checked “Include Embed Comm Interface” in the Code Gen dialog box.
VRCG_FLG_WANT_STACK_CHECK: User wants a stack check.
VRCG_FLG_CALLABLE_FROM_USER_APP: User checked “Make Callable from User App” in Code Gen dialog box.
VR_GET_CODEGEN_TARGET
Returns pointer (LPCSTR) to the name of the current code generation target.
VR_GET_CONNECT_PORT
Indicates if port is input or output.
arg1:   Block handle
arg2:   Port number. If positive, the port is an input; if negative, the port is an output.
VR_GET_CONNECTOR_COUNT
Gets either the input or the output connector count for the block.
arg1:   Block handle
arg2:   If arg2 is 1, it returns the number of inputs; if arg2 is 0, it returns the number of outputs.
VR_GET_CONSTRAINTS
Gets constraint values
arg1:   Double * constraint
VR_GET_CUR_BLOCK_HANDLE
Returns the handle to the current block.
VR_GET_EXPRESSION_ERROR
Returns char * string of syntax or semantic error from prior call to VR_GET_EXPRESSION_RESULT
Returns char * result of expression evaluation
arg1:   char * C expression string
VR_GET_GLOBAL_CONSTRAINT_BOUNDS
Gets global constraint bounds.
arg1:   Double * upper bound
arg2:   Double * lower bound
VR_GET_GLOBAL_CONSTRAINTS
Gets global constraints.
arg1:   Double *
VR_GET_GLOBAL COST
Gets global cost.
arg1:   Double * global cost
VR_GET_GLOBAL_OPT_INFO
Gets global optimization settings.
arg1:   OPT_INFO
VR_GET_GLOBAL_UNKNOWN_BOUNDS
Gets global unknown bounds.
VR_GET_GLOBAL_UNKNOWNS
Gets global unknowns.
arg1:   Double *
VR_GET_GLOBAL_UNKNOWNS_INPUT
Gets global unknown input.
arg1:   Double * global unknown initial
             condition
VR_GET_IMPLICIT_SOLVER_RUNNING
Returns non-zero is implicit solver is running.
VR_GET_INTEGRATION_SUBSTEP
Returns integration substep for multistep methods. Note that 0 means start of new step.
VR_GET_LOCAL_TIME_STEP
Assigns local time step to *arg2
arg1:   Block handle
arg2:   Pointer to double *
VR_GET_OEM_NAME
Pointer (LPCSTR) to OEM name.
VR_GET_OPEN_FILE_PATH
Returns pointer (LPCSTR) to the file name or file path of the active diagram.
arg1:   If 0, then file name; if 1, then file path.
VR_GET_OVERPLOT_DATALIST
Reserved.
VR_GET_PARAM_STR
Returns pointer to parameter string for block handle.
arg1:   Block handle
VR_GET RANDOM_SEED
Supplies the random seed.
VR_GET_RUN_STATE
Indicates if the simulation is running (TRUE) or not running (FALSE).
VR_GET_SOLVER_INFO
Gets settings from Implicit Solver tab in the System Properties dialog box.
arg1:   Pointer to Implicit Solver
VR_GET_STARTUP_DIR
Returns Embed directory string.
VR_GET_STARTUP_SCRIPT
Returns pointer (LPCSTR) to current script file path.
VR_GET_SUB_VERSION
Returns version letter suffix.
VR_GET_TGT_CAPABILITIES
Returns a 32-bit value that indicates the capabilities bit mask for the current or given target.
arg1:   If 0, uses current target; otherwise treats as pointer to the target name
VR_GET_UNKNOWNS_INPUT
Get unknown inputs.
arg1:   Double *
VR_GET_VERSION
Returns major version in high byte and minor version in low byte.
arg1:   SIM_INFO pointer
VR_GET_VISSIM_STATE
Gets current simulation state and copy to pointer in arg1.
VR_GET_WINDOW_HANDLE
Returns Embed main window handle. Useful for model dialog creation.
VR_GRAY_MENU_ITEM
Grays out menu item.
arg1:   Pointer to the menu item name (LPSTR).
VR_MODIFY_BLOCK
Reserved.
VR_NEED_DISPLAY_UPDATE
Returns TRUE if display should be repainted.
VR_NULL
Reserved.
VR_REALLOC_USER_PARAM
Reallocates parameter vector and returns newly reallocated pointer.
arg1:   Block handle
arg2:   New parameter size
VR_RECORD_EVENT
Records an event in the Embed event log.
arg1:   event type (see EVENT_TYPE)
arg2:   LPSTR event message
EVENT_TYPE
tvsmEventMessage = 1
tvsmEventWarning= 2
tvsmEventError=3
VR_REPAINT_BLOCK
Repaints block given by block handle in arg1.
arg1:   if NULL, the currently active block is repainted
VR_REQUEST_PERMISSION
Reserved.
VR_REQUEST_PERMISSION2
Reserved.
VR_RESET_XFERS
For internal use only.
VR_RESYNC_REALTIME_CLOCK
Resynchronizes Embed’s real-time clock to the current time.
VR_RETYPE_CONNECTORS_FROM_SIGS
Requests retyping of connectors based on signal types.
VR_ROTATE_BLOCK
Rotates block 180o.
arg1:   Block handle
arg2:   0
VR_RUN_SIMULATION
Executes the current model.
VR_SET_BLOCK_CONNECTOR_COUNT
Sets the connector count on the block.
arg1:   Block handle
arg2:   input # = upper word
             output # = lower word
VR_SET_BLOCK_FLAGS
Sets block flags. VBF_* are the flogs. OR them together to get the flags you want.
arg1:   Block handle
arg2:   Flag bits (32-bit word)
VR_SET_BLOCK_MENU
Adds user-defined block to Blocks menu.
arg1:   Pointer to initialized USER_MENU_ITEM vector
VR_SET_BLOCK_POS
Sets position of the block.
arg1:   Block handle
arg2 (lower 16 bits):     xPos
arg2 (upper 16 bits):     yPos
VR_SET_CONNECTOR_CHAR
Sets indicator character on block connector.
arg1:   Character to set
VR_SET_CONNECTOR_LABEL
VR_SET_EXPR_BLOCK_HANDLE
Sets the currently active C expression block to the block handle passed in arg1. This enables the C expression evaluator to highlight the block in red in the event of an error.
VR_SET_GLOBAL_UNKNOWNS
Sets global unknowns from supplied vector.
VR_SET_PARAM_STR
Sets new parameter string for block handle. Note that the block will always copy arg2, so arg2 can be freed after the call.
arg1:   Block handle
arg2:   Pointer to parameter string (LPSTR)
VR_SET_RANDOM_SEED
Sets the random seed as an (unsigned int*).
arg1:   (unsigned int*)
VR_SET_STARTUP_SCRIPT
Sets script file.
arg1:   Pointer (LPCSTR) to script file path
VR_SET_UNKNOWNS
Sets unknown values from user-supplied vector.
arg1:   Double * unknown
VR_SET_VISSIM_STATE
Reserved.
VR_SHOW_HELP
Reserved.
VR_SHOW_HELP_ECD
Reserved.
VR_SNAP_STATES
Causes Embed to use current integrator/delay state as initial condition.
VR_UPDATE_STRING
Updates stringPtr in arg1 with newStrValue in arg2, reallocating memory if needed.
arg1: LPSTR* stringPtr
arg2: LPCSTR newStrVal
VR_WF_GET_CURRENT_VIEW
Returns a block handle to the currently open compound block.
VR_WF_GET_SCROLL_INFO
Returns DWORD: upper 16 bits is Y position of scroll thumb; lower 16 bits is X position of scroll thumb.
VR_WF_OPEN_COMPOUND
Sets current view level to compound block.
arg1:   Block handle
