Category: Toolbox > eDrives and Systems > eMotors > Other Tools > Transforms
Description: The Inverse Clarke Transform block provides a magnitude invariant transformation of orthogonal reference frame components [alpha beta] to three-phase signals/systems [a b c]. This Clarke transformation is specific to the case where the primary axis of the three-phase coordinate system is aligned with the primary axis of the orthogonal coordinate system.
The transform is given by:
Diagram name: Inverse Clarke Transform
Location: Examples > eDrives and Systems > eMotors > Transforms
