Knowledge Studio Scoring
Block Category: Extensions
Inputs: The inputs are dependent on the Data Config file. This file specifies the number of inputs and input labels.
Outputs: Standard set of outputs, which can include:
•      inferencetime (ms): The time taken for each input to be predicted or to calculate its probabilities.
•      predictions/probabilities: Matrix output based on the number of predictions. The final sum of the output should be equal to 1 to verify the algorithm that creates the decision tree is working.
•      treeNodeID: The node in which the predicted output is present.
•      treeNodeNumber: The branch of the node in which the predicted output is present.
•      treeNodeWeight: The weight to which tree node input belongs. The weight is used to verify that the algorithm that creates the decision tree is working.
Description: The Knowledge Studio Scoring block uses the specified C file and accompanying Data Config file to generate a DLL that can simulate the response of the decision tree before deploying it on to a hardware for verification.
Data Config File: Indicates the complete path to data configuration file. This file can be a CVS or TXT file.  Click … to browse your directories for the file.
KS Generated C: Indicates the complete path the C file generated by Knowledge Studio. Click … to browse your directories for the file.
