Manipulating a Bode plot
You can easily move, resize, magnify, and delete Bode plots.
To resize a plot
•      Click Maximize in the upper right-hand corner to expand the plot to full screen.
•      Drag the plot’s borders or corners to adjust its size.
To magnify a plot
1.    Point to one corner of the area you want to zoom in on.
2.    To anchor the corner, hold down CTRL+depress.
3.    Drag the pointer until the box encloses the area you want to magnify. A status box in the lower left corner of the plot displays the point position.
4.    Release CTRL+depress.
To zoom out
•      CTRL+right-click over the plot.
To delete a plot
•      Select the plot; then press DEL.
