You may lose a link if you move or rename a source file. If this occurs, you must redirect the link to the appropriate location or file name.
To reconnect an embedded diagram
1. Right-click the embed block, or choose Edit > Block Properties and click the block.
2. In the File Name box, enter the correct path or new file name. If you are unsure of the path or file name, click … to search for the file you want.
3. Click OK, or press ENTER.
