When you choose the Replace in Diagrams command, Embed displays a dialog box to specify the block or text string you want to replace and the directories in which to search for it.
To replace a block or text string with the Replace in Diagrams command
1. Choose Edit > Find and Replace > Replace in Diagrams (CTRL+SHIFT+H).
2. In the Replace in Diagrams dialog box, do the following:
a. In the Find What box, enter the search item to be replaced.
b. In the Look In box:
i. To choose a specific directory to search, click … to select it.
ii. If want to search the subdirectories of the current directory, activate Include Subdirectories.
c. Select the options to refine the search item to be replaced.
Option |
Description |
Match Whole Word |
Finds blocks and text with whole words that match the search item. |
Match Case |
Finds blocks and text that exactly match the uppercase and lowercase of the search item. |
Use Regular Expressions |
Creates sophisticated search criteria using special symbols for the search item. For example, the backslash character (\) indicates that the character that follows it is either a special character or should be interpreted literally. |
3. Choose Replace All. This operation cannot be automatically undone.
To cancel a search or close the dialog box, choose Cancel.
