Bitmaps that are placed on blocks may appear distorted in size under the following conditions:
• You open a diagram and the current screen resolution is not set to the resolution when the bitmaps were originally created
• You change the font size in Embed
To remove bitmap scaling
• Choose Edit > Reset Bitmap Scaling.
