Return flags for WM_VSM_CREATE
Flag
VBF_ALLOC_VEC_OUTPUT
Causes Embed to automatically allocate output matrix for matrix input blocks.
VBF_ALLOW_VEC_CHAMELIONS
Causes connectors to accept scalar or vector connections.
VBF_CANCEL_DLG
Reserved.
VBF_CG_BLK_HAS_NO_RETURN_VALUE
If your DLL has one output, set this if you do not want to use a function return value.
VBF_CG_BLK_HAS_RETURN_VALUE
Reserved.
VBF_CG_EVENT_FUNC
Allows code generation for your DLL event function.
VBF_CG_NEVER
Prevents block from generating code.
VBF_EXECUTE_ALWAYS
Executes the block regardless of graph connectivity.
VBF_EXECUTE_NEVER
Never executes the block.
VBF_HAS_STATE
Indicates that the block has state and can break an algebraic loop. This block is called once, before all other blocks, to present an initial condition; then the block is called during normal diagram execution.
VBF_MENU_ONLY
Indicates a menu item only and no block is created; however, the userBlockEvent() function is called. This flag is useful for menu select to dialog.
VBF_RUN_BLOCK_AT_FRAME_END
Reserved.
VBF_STRAIGHT_WIRES
Causes wires to be drawn as straight lines rather than auto-routing.
VBF_USE_SIGNAL_DESCRIPTORS
Indicates block input and output vectors are of type SIGNAL (not double).
