Sobel Edge
Block Category: Detection
Input Image Format
Input Image Requirements: None
Description: The Sobel Edge block detects the edges of an image in both the horizontal and vertical directions with the detected edges bright on a dark background. The Sobel operator is a discrete differentiation operator. It combines Gaussian smoothing and differentiation, and computes an approximation of the gradient of the image intensity function.
Delta: Specifies a value used to vary the pixel intensity. The delta value is added to the results prior to storing them in the output.
Derivative: Indicates the direction of edges to be detected. There are three supported combinations:
Horizontal derivative
Vertical derivative
Result
1
0
Horizontal edges (y-gradient) detected
0
1
Vertical edges (x-gradient) detected
1
1
Calculates an approximation of the gradient (x-gradient and y-gradient) by combing both the horizontal and vertical derivatives
Horizontal: Indicates an integer variable representing the x-derivative.
Vertical: Indicates an integer variable reprenting the y-derivative.
Kernel Size: Specifies a value used to extend the Sobel kernel. The value must be odd and positive and less than 32.
Scale: Indicates the scale value for the computed derivative values. The scale value helps to visualize a derivative in an image.
In this example, three different outputs are obtained by changing the derivative value.
