Sound Pressure (Microphone)
Creates channel(s) that use a microphone to measure sound pressure.
Additional Information: Refer to the National Instruments NI-DAQmx C documentation.
AnalogInParamSoundP
Excitation Source: Indicates the source of the excitation.
Excitation Value: Indicates the amount of excitation, in amperes, that the sensor requires.
Maximum Sound Pressure Level: Indicates the maximum instantaneous sound pressure level you expect to measure.
Microphone Sensitivity: Indicates the sensitivity of the microphone.
Terminal Configuration: Indicates the input terminal to be configured for the channel.
