Block identifiers – or block IDs – are unique names that you can apply to individual blocks. You use a block identifier to mark a block that you want to find quickly using the Edit > Find and Edit > Find in Diagrams commands.
To add an ID to a block
1. Choose Edit > Assign Block Id.
2. Click the block to be assigned an identifier.
3. In the Assign Block Identifier dialog box, enter the identifier and click Assign. Block identifiers can consist of alphanumeric and special characters.
4. Save the diagram.
To remove an ID from a block
2. Click the block whose identifier is to be removed.
3. In the Assign Block Identifier dialog box, enter the identifier and click Remove.
