Specifying the counter set mode value
The Counter Set Mode lets you reset the counter on your MFIO-3A board to the value specified in the Counter Reset Value box. You have the following choices:
      You can reset the counter at the start of the simulation.
      You can reset the counter at the first occurrences of the index pulse (which is also known as the Z trigger).
      You can reset the counter at every occurrence of the index pulse.
You can alternatively not ever reset the counter.
