Category: Toolbox > eDrives and Systems > eMotors > Sources
Description: The Three Phase Square Wave Inverter block provides bipolar three-phase square wave output from an input frequency.
Negative Rail Voltages: Defines the lower voltage rails for inverter supply.
Positive Rail Voltages: Defines the upper voltage rails for inverter supply
Diagram name: Three Phase Square Wave Inverter
Location: Examples > eDrives and Systems > eMotors > AC Induction
The following illustrates a simple example of frequency control of a three-phase AC induction motor. Typically, the stator voltage is adjusted in proportion to frequency to maintain a constant flux. This provides easier adjustment of speed.
