Category: eMotors > Sources
The Three Phase Square Wave Inverter block provides bipolar 3-phase square wave output from an input frequency.
Positive Rail Voltages: Defines the upper voltage rails for inverter supply
Negative Rail Voltages: Defines the lower voltage rails for inverter supply.
Diagram name: Three Phase Square Wave Inverter
The following illustrates a simple example of frequency control of a 3-phase AC induction motor. Typically, the stator voltage is adjusted in proportion to frequency to maintain a constant flux. This provides easier adjustment of speed.
