Category: eMotors > Sources
The Triangle Wave Generator block provides a symmetric triangular wave signal of amplitude 1 from a specified input frequency. This block is generally used as a basic element in motion control applications for generating various pulse-modulation schemes for motor drives.
Diagram name: Triangle Wave Generator
In this example, three comparators are used to create logic states for 3-phase PWM from the triangle wave generator. A null offset of 1 Hz was used in this example.
