The fundamental means of setting up the exchange of data between an Embed simulation and an embedded Mathcad document is the use of the keywords inx, and outx in the embedded Mathcad document.
• The keywords in0, in1, in2,… refer to the input connector tabs on the embedded Mathcad document, where in0 corresponds to the top input connector.
• The keywords out0, out1, out2,… refer to the output connector tabs on the embedded Mathcad document, where out0 corresponds to the top output connector.
Note that all keywords must be lowercase.
