Status Bar
The status bar is a small toolbar that shows the line and column number for the current cursor position as well as the setting for the text editor (insert or overwrite).
The status bar is located at the bottom-right of the application window. Options on the status bar are also available on the ribbon, but since the status bar is always visible, they are easily accessible no matter which ribbon tab is selected.
