Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard,
mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D
views are supported.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. Use
the field/current definition when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from
your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces
and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to
analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for
each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved
parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling
into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
Cable harnesses are becoming increasingly complex with innovations in the automotive industry. Import a complex cable harness
from a .kbl file using the “harness description list” (KBL) specification.
When creating a cable shield, you need to specify for each layer the impedance and admittance. The following combinations
are supported when defining the impedance and admittance for a shield layer.
Create a single layer, braided (Kley) cable shield. The relevant braid parameters, weave metal and braid-fixing materials (optional) are specified
and the Solver determines the frequency-dependent impedance (Zs + Zt) and admittance (Yt) matrix using the Kley formulation.
Create a single layer, braided (Vance, Tyni, Demoulin) cable shield. For a braided shield layer, the relevant braid parameters and weave metal are specified and the
Solver determines the frequency-dependent impedance (Zs + Zt) and admittance (Yt) matrix using the Vance, Tyni or Demoulin formulation.
The transfer capacitance shield layer is used with a braided and frequency-dependent impedance definition to represent
the transfer admittance matrix of the shield layer.
A double cable shield consists of two shield layers. CADFEKO supports any combination of the shield types, solid, braided and frequency-dependent for the inner and outer layer
of the shield.
For a complex cable harness, it is not a simple task to find a specific cable instance in the 3D view. Use the “Find cable” tool to locate a cable instance.
The cable schematic view allows you to add cable ports, complex loads, resistors, capacitors, inductors, external SPICE
circuits, general networks (defined using N-port Touchstone files) and probes to a specific cable harness as well as connecting
cables to one another.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency
range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated
or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port
to add sources and discrete loads to a model.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement
to create multiple models with different solution requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced
as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready
model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using
a calculator, measure distances, measure angles and export images.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Creating a Braided Cable Shield Layer (Vance,
Tyni or Demoulin)
Tyni or Demoulin
formulation.
The Vance, Tyni and Demoulin formulation models
the coupling mechanism accurately due to the field penetration through the shield
apertures.
On the Cables tab, in the
Definitions group, click the Cable shield icon.
Under Shield layer(s), click
Single to create a single-layered shield.
On the Inner layer tab, on the Impedance
definition tab, from the Definition
methoddrop-down list, select one of the following:
Braided (Vance)
Braided (Tyni)
Braided (Demoulin)
Figure 1. The Create cable shield dialog.
Under Weave, specify the following:
From the Definition methoddrop-down list, select Weave angle
to create a braided layer using the weave angle definition:
In the Weave angle (degrees) field, enter
a value in degrees for the nominal weave angle.
In the Deviation (+/-) (degrees) field,
enter a value for the deviation of the weave angle from the
nominal weave angle in degrees.
From the Definition methoddrop-down list, select Optical
coverage to create a braided layer using the optical
coverage definition:
In the Minimum optical coverage (%)
field, enter a percentage for the minimum optical coverage for
the braided layer.
In the Number of carriers (m) field, specify the
number of carriers in the braided layer.
Under Filaments, specify the following:
In the Number of filaments (n) field, enter a
value for the number of filaments in a single carrier.
In the Diameter (d) field, enter a value for the
filament diameter.
In the Filament metaldrop-down list, select one of the following:
To create a filament consisting of PEC, select
Perfect electric conductor.
To create a filament consisting of a predefined metal, select
the metal.
To create a filament consisting of a metal, which is not yet
defined in the model, select the icon to define a metal or add a metal from the media
library.
Note: The Thickness of a Vance,
Tyni and Demoulin
shield layer is two times the filament diameter (d).
On the Inner layer tab, on the Admittance
definition tab, select Same as impedance
definition, from the Definition methoddrop-down list to use the Vance, Tynior Demoulin formulation for the admittance matrix.
Figure 2. The Create cable shield dialog.
Note:
The weave and filaments values are used from the impedance definition to
calculate the admittance matrix.
In the Label field, add a unique label for the cable
shield.
Click Create to create the cable shield and close
the dialog.
